Author Topic: throttle body options  (Read 8569 times)
nickmpower
« on: August 03, 2006, 03:13:34 PM »
well, if the m42's TPS is a potentimeter, and takes the input of exactly how far the TB is open, it may not work to have a larger, differnt style throttle body on there which includes ITB's??? I think this really stinks becaue i have been wanting to build some itb's oh so bad.
the other option is boring the current one out. Does anyone know if universial throttle butterfly's are avalible? then you could just have a machinist bore out the body, and buy a butterfly to fit?
what do you guys think?
haledj
« Reply #1 on: August 03, 2006, 09:55:02 PM »
I think someone should use 4 throttle bodies- one for each cylinder, that would be hot.  But as for the other bit, IDK:confused:
StreetSpec_iS
« Reply #2 on: August 11, 2006, 09:20:01 PM »
this is something that i've thought about before also.
the main way to implement it would be to have a custom plenum fabbed, then run a larger, single TB on the nose of it.
ie, something like:
anyone know anything about TPS interchangeability?
///Motorsport
« Reply #3 on: August 17, 2006, 12:01:23 PM »
man individual throttle bodies would be so badass. someone do it now.
Febi Guibo
  • m42 reporter
« Reply #4 on: August 17, 2006, 12:37:28 PM »
hello? tim_s, or should I say, --the man!-- has done it:
http://www.m42club.com/forums/showthread.php?t=982
Support M42club.com !!
« Reply #5 on: August 17, 2006, 01:37:21 PM »
Slide-throttles.  Dooo it.
tim_s
« Reply #6 on: August 19, 2006, 05:29:44 AM »
Quote from: nickmpower
i believe you're correct about the TPS being a problem. There's a chap over here with an e36 m42 on ITBs and he's having trouble trying to get motronic to work with his ITBs due mainly to this. I think running motronic would be a real waste without a MAF/MAP conversion and a serious remap anyway, else you just won't get the best out of throttle bodies performance-wise.
I didn't even bother trying to get my setup to run off the factory motronic. I'm running megasquirt for fuel and sparks, and as a result have a restrictionless intake (no AFM/MAF etc) and instant throttle response.
2.1 200bhp, 175ft/lbs 318is
E46 330ci daily
BrandC
« Reply #7 on: August 19, 2006, 04:44:17 PM »
I think a MAP conversion/stand alone will help an ITB setup run a lot smoother.
As far as the TPS, you just have to find out the voltage range. Find a similar TPS from another car (easier said than done), but if you seriously ask around on other forums I'm certain you can find a similar voltage potentiometer TPS.
tim_s
« Reply #8 on: August 19, 2006, 04:54:40 PM »
Quote from: BrandC
nah think you're missing the point!
The problem is, in simple terms, say at 50% throttle given on the TPS, on the ITBs you have way more air going into the engine than with the standard throttle body, which confuses the hell out of the motronic, even if you use a standard BMW TPS.
if you think in terms of change in manifold pressure versus change in throttle position with the standard throttle body and with 4 throttle bodies with say almost 3 times the surface area (as mine have), you realise that what's called TPSdot in MS terms (rate of change in TPS), and change in TPS value in absolute terms, doesn't correspond to the same change in manifold pressure. As a result acceleration enrichment etc gets screwed up, and from the experiences of the guy with the e36 I mentioned (I have no firsthand experience because I went MS), this theory proves true in practice.
« Last Edit: August 19, 2006, 05:07:52 PM by tim_s »
E46 330ci daily
silverblades181
« Reply #9 on: August 19, 2006, 06:57:55 PM »
think an alpha-n type intake could be fitted to a 4 throttle body M42?
E30 318is 1991 (Brilliantrot)
Bayerisch Motoren Werke
BrandC
« Reply #10 on: August 20, 2006, 05:34:19 AM »
Quote from: tim_s
Understood. Hopefully you find a solution, I'd really like to see video footage of the car in action!
tim_s
« Reply #11 on: August 20, 2006, 02:11:50 PM »
Quote from: BrandC
thanks, but i'm afraid I won't be coming up with a solution as I run megasquirt which has no probs of this nature and i can program specifically for my setup. I did this in the knowledge that i'd never get the best out of the setup with motronic!
I will make a video when i borrow something which has sound (my digi cam doesn't), the car sounds great on the ITBs and with the 2.1!
E46 330ci daily
E30own'er
« Reply #12 on: January 02, 2007, 03:57:01 AM »
tim ... if i want my 85 318i into the same kind of manifold as urs with ITB's where should i look for throttle bodies and what size , ect , how to custom a manifold what should be the best and can i shoot it stright off the block?
tim_s
« Reply #13 on: January 02, 2007, 02:57:26 PM »
85 318i is an M10, no? If so, there are quite a lot of kits and inlet manifolds out there that will fit. Throttle body size is fairly complex to get right, iirc jenvey.co.uk has some good reading on this.
E46 330ci daily
