Any feedback for a CA smog compliant exhaust replacement for a 91 E30 318ic? M42 motor. PO had a quiet exhaust installed, but the rear three metal hanger/straps on the exhaust are torn. The rear two straps were welded on to the muffler itself as the replacement muffler was 1/2 the diameter. BTW, the mount points on the body all look fine.
I can have the mounts repaired or just replace H/W from the cat back. I read folks using Magnaflows as weld in replacements, but don't know if they will pass CA smog inspections.
Any feedback on what you may be using? for the Vert, I'm not interested in increasing it's sound, but wouldn't mind a healthier tone.
Thanks! :cool:
