Author Topic: Sachs Stage 3 Performance Clutch  (Read 3144 times)
M42_Jester
« on: August 29, 2009, 10:20:18 PM »
Ok, so went and got a sevice and my mechanic told me that he is worried about my clutch. he told me that it's not slipping, but that it feels a bit heavy...so i should take care of it, and contact him if i have any problems.
What i've been looking at doing for a while though is a rebuild, and in turn, a new clutch that can handle the extra horsepower that i will be giving my baby. and i've come across this:
http://cgi.ebay.com/ebaymotors/1990-99-BMW-318-Z3-1-8L-1-9L-E30-E36-STAGE-3-CLUTCH-KIT_W0QQcmdZViewItemQQ_trksidZp4634Q2ec0Q2em14Q2el1262QQhashZitem29fdf7a33dQQitemZ180354523965QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
never bought a clutch, so i don't know wats wat. i've heard that Sachs are good...but just not sure. my mechanic used to be the head mechanic for BMW here on the Gold Coast for 20 years...so i might ask him...but wanted some feedback from other M42ers.
Cheers,
Jester
HATER-PROOF
« Reply #1 on: August 30, 2009, 02:03:43 AM »
I would show the mechanic the site and let him tell you if it's worth it.
quinn11m20
« Reply #2 on: August 30, 2009, 02:55:29 PM »
SPEC clutch and CenterForce make great clutch's for our BMW's. ANd they are a reputable source as well.
JP 91iS
Info copied from UUC website
« Reply #3 on: August 31, 2009, 12:15:20 AM »
I've never bought a clutch but I was reading this the other day so I thought I'd pass it on.  Copied from UUC Motorwerks website:
Quote
How to choose a clutch
  The selection of the correct clutch for the   intended application is critical to good operation, including the   characteristics of (but not limited to:
  • clutch feel
  • operating temperature range
  • wear characteristics / durability
  • clamping force
  • break-in period
Quite often, the first impulse is to get   "too much" clutch.  This is often a very big mistake, as there   will be compromises in some or all of the operational features listed above.
   The first step in identifying what clutch to   get is dependent on the characteristics of the car.  Ask these questions:
  • How much power does the car make?
  • How is it used?  Street driving or       track use?  If for racing, what kind of racing?
As we are dealing with BMW applications here,   let's use an widely-understood example - the 1992-2004 6-cylinder 3-series.    Over this 12 year period comprising two different chassis, we are still   dealing with virtually the same fundamental engine and transmission designs.    Power ranges from around 190hp to 333hp.  Typical bolt-on modifications   bring many of the early models up to the 215hp-260hp range and later models   around 350hp.  Extensive modifications including supercharging or   turbocharging bring power to the 350hp-450hp range, with some examples in the   500hp-600hp range.  The typical BMW enthusiast uses the car primarily for   sporty street driving, and the occasional auto-x or track day.  The   3-series is also popular as a heavily-tracked car and dedicated race car.    Some see time spent drag racing, whether occasionally or as dedicated drag   racers.
  So it is apparent that we have a broad range of power and use to contend with.
  Presented in increasing "aggressiveness", here is a brief overview   of clutch compounds, their power handling, and other characteristics:
  (note that hp figures are generalized, pressure plate clamping force and   torque curves are additional factors)
                             organic                       CHARACTERISTICS         Metal-fiber           woven into "organic" (actually CF aramid with other           materials), original-equipment style.  Known for smooth           engagement, long life, broad operating temperature, minimal-to-no           break in period.  Will take hard use, somewhat intolerant of           repeated abuse (will overheat).  Will return to almost full           operational condition if overheated.  Material           is dark brown or black with visible metal fibers.                         USE         Street-driven           cars up to 400hp, auto-x and track use.
You can find the rest of the article at their website. Click product catalog > then use the links on the left side to navigate to their section on performance clutches.
-JP
Project M42: generating funds
nickmpower
« Reply #4 on: August 31, 2009, 12:22:17 AM »
use an m20 flywheel with m3 clutch
JP 91iS
« Reply #5 on: August 31, 2009, 12:45:01 AM »
-JP
