Author Topic: Why does my e30 m42 sound like a diesel engine?  (Read 8703 times)
dblmikeusa1
« on: August 29, 2009, 10:10:29 PM »
When I start it and let it idle the car sounds like a diesel.
what I know:
It has oil,
No idea if the chain tensioner has ever been replaced
Any one have an idea?
I will be replacing the valve cover gasket soon as oil is leaking from that area...
teh Phil
« Reply #1 on: August 30, 2009, 01:20:26 AM »
Take a long screwdriver and hold use it like a stethoscope on your timing chain cover. Is it coming from there?
roundel318
« Reply #2 on: August 30, 2009, 08:39:10 AM »
some guy was doing a first start on a buildup and wasnt getting oil to the top end, it sounded very much like a diesel.
KenC
« Reply #3 on: August 30, 2009, 08:55:22 AM »
Make sure your spark plugs are seated well.
dblmikeusa1
« Reply #4 on: August 30, 2009, 02:16:02 PM »
Quote from: roundel318;77622
Was this on this site? What ended up being the issue?
Quote from: KenCopperwheat;77626
I will check that... curious how that would cause the issue...
Quote from: teh Phil;77612
Will check soon
1991 E30 M42
« Reply #5 on: August 30, 2009, 09:43:59 PM »
the last two m42's i had that sounded like a diesel the problem ended up being tore up rod bearings from sustained high rpm abuse
roundel318
« Reply #6 on: August 30, 2009, 09:49:46 PM »
http://www.youtube.com/watch?v=goq3BWyl9Wk&feature=channel_page
then fixed at
http://www.youtube.com/watch?v=YuEMfLMKbEE&feature=channel_page
"Finally after no oil getting to the head the m42 is sounding right! "
ob_318is
« Reply #7 on: August 30, 2009, 10:22:22 PM »
I think this is a cylinder head problem. When i first purchased my 318, it sounded like a diesel truck (i remember some girls in a suv laughing at my sh*t)...but yea, turned out that I had a warped head, after replacing it, all was well...
dblmikeusa1
« Reply #8 on: September 13, 2009, 10:12:27 PM »
Quote from: roundel318;77646
then fixed at
Was it an oil pump? something clogged or broken?
Deftones
« Reply #9 on: September 14, 2009, 06:57:50 AM »
that sound is because the chain tensioner is empty of oil and until the oil gets inside and make pressure the chain is free to move and cause that noise.
i have a problem like yours, car seems running like disel at idle but after running a lot and high rpms the problem disappear, i think it's probably a combination of rich carburation (i have turned the screw on the maf), used plugs and maybe throttle heating deleting which cause bad combustion...
http://blogs.yahoo.co.jp/luca318is
1992 318is e36
1990 318is e30
Asserti
« Reply #10 on: May 07, 2010, 03:53:46 PM »
where you able to find the problem?
[/URL]
jon885
« Reply #11 on: June 11, 2010, 01:00:51 AM »
old thread revival!!
jmsra
« Reply #12 on: July 04, 2010, 12:56:17 PM »
I had the diesel sound after replacing the head gasket.
It turns out it was the cam gears off by one tooth exactly.
If you've never had the chain off then i would take a guess that your timing components are pretty well worn and causing the same result as being a tooth off on both cam gears. Good Luck!
lookitsranday
« Reply #13 on: October 18, 2011, 01:33:17 PM »
this happened to me where everytime i rev or in high rpm it sounded like a turbo school bus was in my e30. i replaced fan clutch and water pump (all the belts while i was there) the turbo sound was now gone.
