FAQ / REFERENCE
How-To's
secondary plate of your throttle-body bored out
Topic: secondary plate of your throttle-body bored out (Read 4797 times)
jens
Jr. Member
August 28, 2009, 04:05:01 AM »
Can someone show me how to do this, pic please.
"get the secondary plate of your throttle-body bored out 3mm to 57mm. This will make a difference."
http://www.racingforum.pl/lofiversion/index.php?t50795.html
[SIGPIC]Delete [/SIGPIC]
JP 91iS
Hero Member
August 28, 2009, 12:18:01 PM »
What other mods are you planning to go with the throttle body bore out? (FWIW
Metric Mechanic
doesn't bother with a bigger bore TB.)
http://www.m42club.com/forums/showthread.php?t=7678
http://www.m42club.com/forums/showthread.php?t=5510
-JP
Project M42:
generating funds
Legendary
-Receive: 5
August 28, 2009, 12:30:24 PM »
This is a waste of time.
jens
Jr. Member
August 28, 2009, 04:48:47 PM »
So what shall I do, I have deleted heat plate. What more can I do.
Legendary
-Receive: 5
August 29, 2009, 12:54:58 AM »
Get rid of the 2" intake restrictor
http://www.m42club.com/forums/showthread.php?t=5561
22# EV6 injectors
http://www.m42club.com/forums/showpost.php?p=49757&postcount=70
Unless you're a girlyman you can ditch the PS and find a cheap fleabay chip. Enjoy your 130+ HP at the wheels. I assume you don't have a lot of freeways in Iceland so taller gearing isn't really an issue for long distance driving, but a 3.73 diff will get you to 100kph in second gear and its also very nice for autoX
good luck
Justin
FAQ / REFERENCE
How-To's
