Author Topic: Need Timing Help  (Read 6240 times)
VictoryChaser
Need Timing Help
« Reply #15 on: September 13, 2009, 03:19:44 PM »
Hey, im glad youve solved your problem. I just did my head gasket and i dont know how to set my crank to TDC so that I can set the cams off that. How exactly did you get to TDC? thanks in advance
Murdul
Need Timing Help
« Reply #16 on: November 09, 2009, 06:40:40 PM »
Its been two months, been busy.  Took the timing chain off and adjusted my timing once more.  I had run out of room within the sprockets.  Anyway car starts and runs great.  I don't know if there is any damage internally, but nothing about the way the car runs is telling me to worry.  I rotated the engine by hand and never felt any binding or heard anything unusual.  Time will tell either way.
The problem as far as I can tell was when I put the chain on I tightened the sprockets down and did not move the slack in the chain over to the tensioner side of the engine.  So there was some slack which ruined my timing just enough.
nicknikolovski
Need Timing Help
« Reply #17 on: November 10, 2009, 04:47:20 AM »
Thats great news. Well done. So the engine is running ok - no noises, good idle?
Murdul
Need Timing Help
« Reply #18 on: November 10, 2009, 09:49:50 AM »
Idle is good, no weird noises.  The engine is still noisy but it sounds good.
Thanks for everyones help.
