Author Topic: So they didn't come stock with a LSD  (Read 3138 times)
Ramblin MAn
« on: August 24, 2009, 10:14:53 PM »
I had my car up on the rack. How do I tell if I have a LSD? I think I do because when I was trying to tell I couldn't rotate the left wheel more than X degrees without moving the right wheel. But shouldn't there be a tage or something? I didn't see an S stamped on it like the e21s
roundel318
« Reply #1 on: August 25, 2009, 11:56:18 PM »
in neutral, spin the back wheels forward, if the other goes the opposite direction, i belive its a open (non LSD) and if it goes the same its a closed (LSD)
someone correct me if i am wrong, that is just off the top of my head.
JP 91iS
« Reply #2 on: August 26, 2009, 11:27:55 AM »
yes same direction spin is lsd
-JP
Project M42: generating funds
Ramblin MAn
« Reply #3 on: August 26, 2009, 12:22:07 PM »
My car has issues. The rotors are all rusty and the brakes are grabbing. On my e21 if I rotate one wheel the other rotates also in the smae dirrection, but like I said this car has issues. If I am lucky I will have the rack this weekend and I'll get the rotors off and drop them off to get turned while I'm puting the gas tank back in.
Choking Hazard
« Reply #4 on: September 10, 2009, 09:07:48 PM »
I loved my E21.  Euro spec 320 with Hartge goodness.  An 18 wheeler tested the side impact beams I had put in... and they passed.  :(
[SIGPIC][/SIGPIC]-Scott
Ramblin MAn
« Reply #5 on: September 10, 2009, 09:39:54 PM »
MMMMMmmmmmmm Hartge.
My e30 has an LSD. When I was putting the drive shaft back in, enough rust had wore off the rotors to allow them to spin free. When I turned the drive shaft, both wheels spun. It was that motor week video that scared me. They said it was an option.
Bunta
« Reply #6 on: September 13, 2009, 01:41:24 PM »
Theres a little metal tag on one of the diff cover bolts that says if its an LSD or not.
It'll say S4.10 is it's an LSD a little sand paper will make it easier to read.
Luckily both my cars had the LSD option.
Hunter
