DISCUSSION
Engine + Driveline
ACPT carbon fiber driveshaft
Topic: ACPT carbon fiber driveshaft (Read 3163 times)
HATER-PROOF
August 18, 2009, 04:09:39 AM »
I'm up in the air of deciding to purchase a carbonfiber driveshaft for my E36 that's not a daily driver. If this DS would allow more torque to the ground with a KAAZ LSD from horsepower freaks, then I would think that's it's capable of doing such. I'm not familiar with rear-end torgue, but I'm trying to achieve maximum traction in the axle. Give me your thoughts?
http://www.acpt.com/driveshaft/driveshafts.html
BraveUlysses
Jr. Member
August 18, 2009, 09:56:11 AM »
Both are a waste of money. Just swap a M3 diff in and call it good.
romkasponka
Hero Member
-Receive: 3
August 18, 2009, 01:14:26 PM »
I think both mods are right, kaaz lsd will be new with more clutch discs inside, that mean more stable and longer use.... Light driveshaft is because you loose weight, you will loose inertia in transmision and that mean better acceleration.
E30 318is M42
E36 318is M44
DISCUSSION
Engine + Driveline
