Author Topic: starting... and slugish  (Read 2489 times)
B318M42W
« on: August 17, 2009, 08:47:19 AM »
I don't know why, but it takes forever to start the engine. 2 months ago, hot/cold it started on the 1/4 turn...  now, it takes about 5-10 seconds of cranking to get it going hot or cold. however, if i cut it and restart in the following minute, it starts right away. also, if i turn the fuel pump off, it will stall within 2 seconds (as before it took about 5-10 seconds).  It also feels sluggish on accel.
Recent parts replaced: Fuel pump (used), fuel pressure reg(used). fuel filter(new). i use shell 91 for gas
thanks for any input!
M90 Blown M42 :cool:
bearsbmw
« Reply #1 on: August 17, 2009, 09:51:24 AM »
sounds like a weak fuel pump
B318M42W
« Reply #2 on: August 18, 2009, 12:47:37 PM »
finally got down to ''digging in'' and found that i had air bubbles passing through the fuel lines... swapped the fuel pump hanger and fixed the bubble problem, however, the no-return valve is busted so fuel does flow back into th tank via the fuel pump. guess i need a new valve...
