I have the stock 19lb flywheel. I told the shop I wanted 4mm shaved off the back and then whatever it took on the front to be able to balance it easily.
I want to take 4mm off the back first because I dont want to have to use the spacer, and Ive read that 3mm needs taken off and then Ive also read 6mm needs taken off, so Im gonna play it safe and shoot low for 4mm. If it hits the block Ill then grind the block.
Anyways, they told me itd be hard to balance, and that its a lot of weight to take off. I told him if he could get it down to 16lbs and balanced that would be great. They didnt want anything to do with it.
To my knowledge, this is possible and shouldnt be a problem.
