Author Topic: left fog light!  (Read 2657 times)
TOPAK[e30]
left fog light!
« on: August 11, 2009, 12:05:10 AM »
alright just lately i was driving my car and suddenly my left fog light goes out.. .. and i look at it but nothing seems to be wrong.. .am i missing somethin or what?!?!?! anyways its also moving from were it is, like i can push it back but on the other fog light (the right one) it stays in position thats all i can tell so far.. . so any help or suggestions would be great thanks!
HATER-PROOF
left fog light!
« Reply #1 on: August 11, 2009, 01:44:06 AM »
Are you sure the bulb isn't bad? because you might have to replace it.  If the right FL is in working condition, then it's not the fuze-----check your wire connections.  Also look at your L-foglight bulb really close to make sure it isn't burned out, I mean REAL-CLOSE.
romeomike
left fog light!
« Reply #2 on: August 11, 2009, 07:12:02 PM »
Take your pick: the lamp, fuse 29, or the two-wire connector in the engine compartment. In the recent past, I've dealt with all three.
left fog light!
« Reply #3 on: August 11, 2009, 07:16:59 PM »
I had some corrosion in my housing from a cracked lens that kept mine from working.  I swapped it with a nice one and that fixed the problem.  The bulb was still good, if you can believe it.
TOPAK[e30]
left fog light!
« Reply #4 on: August 12, 2009, 05:05:12 PM »
alright ill check those out thanks again.. ill come back with more results
