Author Topic: Half the Instrument Cluster failure  (Read 4294 times)
M42_Jester
« on: August 06, 2009, 07:49:36 PM »
as mentioned in the title, only half of the instrument cluster has failed. my tahometer, temperature gauge and my L/100km gauge has failed and i don't know why.
any thoughts?
Cheers,
Jester
HATER-PROOF
« Reply #1 on: August 07, 2009, 03:24:37 AM »
Jester-by any chance you took the front clear plastic window off from it's glued plate?
romeomike
  • -Receive: 2
« Reply #2 on: August 07, 2009, 09:21:22 AM »
Check fuses 10 and 21 and replace any blown ones you find.
On Christ the solid Rock I stand, all other ground is sinking sand. (Edward Mote 1797-1874)
M42_Jester
« Reply #3 on: August 11, 2009, 11:05:20 PM »
Quote from: HATER-PROOF;76471
How do you mean? i did remove the plastic window in order to put a brushed aluminium bezel on, but why would that stop the tach, temperature gauge and the L/100Km gauge from working?
Jester
cleaner32
« Reply #4 on: August 11, 2009, 11:12:09 PM »
Slap the dash
HATER-PROOF
« Reply #5 on: August 11, 2009, 11:31:40 PM »
I've done that before, just to change the bezel and I took that plastic shield off and when I put it back on---even though the fuses were all brand new, weird crap was going on-that's why I asked.
M42_Jester
« Reply #6 on: August 13, 2009, 03:43:46 AM »
ah k. i've done it before when i installed my plasma gauges...but nothing like this has happened before. it's weird. all the gauges on the right side just don't work...
the fuses are fine...i checked all of them... so other than a wiring issue, wat else could it be?
Jester
« Reply #7 on: August 13, 2009, 05:22:58 AM »
E30 or E36? I'm guessing E36 from your profile picture.
Does your SI board work?
M42_Jester
« Reply #8 on: August 14, 2009, 07:39:23 PM »
Quote from: ak96ss;76798
Forgive my ignorance, but wat is this?
and yes. it is an E36 318iS
Jester
« Reply #9 on: August 14, 2009, 09:14:24 PM »
The Service Indicator lights.
M42_Jester
« Reply #10 on: August 15, 2009, 04:20:47 AM »
yes the service lights still work...but they don't turn off anymore. does that hav something to do with it?
Jester
« Reply #11 on: August 15, 2009, 05:00:43 PM »
In an E30, yes. In an E36, I don't know, I don't have an E36 ETM.
M42_Jester
« Reply #12 on: August 16, 2009, 06:59:10 PM »
cheers for the help anyway mate. she's due for a service soon anyways, so i'll pop into the auto electrician while i'm there. maybe they can figure it out.
cheers,,
Jester
