Author Topic: Calculator shows only 102mph @ 7K with a 4.45 rear diff?  (Read 3498 times)
JoeDellio
« on: August 06, 2009, 06:34:41 PM »
for the E36, I was using these numbers and this is what came up with a 205/55/16 tire.
1st 4.23, 2nd 2.51, 3rd 1.67, 4th 1.23 and 5th 1.1
I dont see how anybody could drive on the highway with the 4.45 if this holds true, it would be screaming at 80mph!
Im about to buy one (Im on a buying spree, engine, M20 FW/clutch, and now this), but I have to drive to FL soon and I dont want to kill my car on the way at 5K for 20 hours.
« Last Edit: August 06, 2009, 07:00:54 PM by JoeDellio »
[SIGPIC][/SIGPIC]1995 318i
Calculator shows only 102mph @ 7K with a 4..45 rear diff?
« Reply #1 on: August 06, 2009, 07:40:49 PM »
5 speeds had a 3.45 differential. Automatics have 4.45. Why would you put a 4.45 on a 5 speed? The gear ratios are already too short. You can't even get to 60mph in second. Go taller.
« Last Edit: August 06, 2009, 07:46:56 PM by tjts1 »
JoeDellio
« Reply #2 on: August 07, 2009, 06:26:52 PM »
Its the only LSD with a small case available locally for $300 that will bolt on my E36.
« Reply #3 on: August 07, 2009, 06:34:13 PM »
Can you fit a large case? I don't know E36 very well.
JoeDellio
« Reply #4 on: August 07, 2009, 11:53:24 PM »
Quote from: tjts1;76512
A large case from a M50 will fit, but it requires me to also swap in the rear axles and cups, plus the rear section of the driveshaft. Then we are talking big bucks for an already expensive rear diff. I may just have to hunt for a locked 3.45.
Hodge
« Reply #5 on: August 08, 2009, 06:57:59 AM »
Like I told you in the other thread, a 4.45 will absolutely suck for everything but city driving. Even then, it will probably suck since your gears will be so short.
1995 E36 318isc
JOMARO
« Reply #6 on: August 14, 2009, 03:12:04 PM »
i have it on my e30... and it pulls really hard in every gear .. i dont even have to shift down sometimes while passing others.. but it really sucks on highways ..top speed 125 on 14"basket weaves with 185/65   and it over heats if i stayed there for a while . really sucks if u ask me .. the only thing that made me use it , is the fact that i m going to autox my car.... but i m seriously thinking to go for something lower ... where i can hit 60 in sec gear ..
« Last Edit: August 14, 2009, 03:14:23 PM by JOMARO »
Hodge
« Reply #7 on: August 14, 2009, 05:31:29 PM »
3.45 LSD in my E36 and I still can't hit 60mph in 2nd. I kinda wish I went 3.23 or thereabouts. WOuld hurt acceleration but would allow me to not shift as often.
1995 E36 318isc
« Reply #8 on: August 14, 2009, 11:02:24 PM »
E30 and E36 transmissions are completely different. You really can't compare the two when speaking about the same diff ratio.
Danny707
« Reply #9 on: August 15, 2009, 12:13:11 AM »
Take both diffs apart and put the clutch packs in the 3.45
