Author Topic: JUST did COP conversion, still pulling a 1271 code wtf  (Read 4662 times)
fiftytakedowns
« on: August 05, 2009, 01:40:47 AM »
The Car doesnt misfire at mid RPMS anymore, but still bogs down when cold.
WTF
fiftytakedowns
« Reply #1 on: August 05, 2009, 01:42:39 AM »
« Reply #2 on: August 05, 2009, 01:47:55 AM »
Did we try swapping the AFM from my car? I don't remember. Bad AFM can have weird symptoms. At least you eliminated the ignition system.
fiftytakedowns
« Reply #3 on: August 12, 2009, 01:31:00 AM »
Car DOES STILL misfire at mid RPMS. WUT is going on
Danny707
« Reply #4 on: August 12, 2009, 01:45:28 AM »
I have an AFM for sale in Vacaville, 20 mins away.
3bvert
« Reply #5 on: August 14, 2009, 03:56:04 PM »
cam sensor ?
I just ordered all the sstuff to do a cop conversion, so this thread caught my eye
I just finsihed a battle with a mid range stutter.and it seemed like it was bogging down, yet the stomp test showed no codes !!. stutter would come on about 3k up to about 4k. would mostly notice when held at those rpms, crusing the freeway, not  showing up going through them in a fast upshifting drive
on antoehr froum it was suggested the afm, or the crank sensor , or the cam sensor. luckily I had spares of each.
replaced the cam and crank sensor as a pair, problem gone
then a few days later when I had more time, started switching one at a time, so I could see which was really the bad one,( and trash the dead one)  started at the top ( cam)
did nto have to test any further
my engine (some suggested from tjts threads) remove throttle heater and hoses, 4 pintle injectors, volvo fan, chipped, ac delete, ps delete, magnaflow mufler
fiftytakedowns
« Reply #6 on: August 15, 2009, 04:02:12 AM »
Quote from: Danny707;76747
I already got a spare working one :/
fiftytakedowns
« Reply #7 on: August 15, 2009, 04:03:43 AM »
Next time I hit up a junkyard, I'll definitely pick up a Cam sensor.
KenC
« Reply #8 on: August 15, 2009, 09:39:16 AM »
Mine still throws this code too, but my symptoms are gone.
It's really easy to test the crank and cam sensors with a multimeter.
3bvert
« Reply #9 on: August 15, 2009, 10:00:51 AM »
Quote from: KenCopperwheat;76904
really ?
are you just checking continuity or a specific number....can you explain so I can see if my others are within limits too
and I still find it interesting, that I had a cam sensor go bad, and not have it show up on the codes
KenC
« Reply #10 on: August 15, 2009, 10:44:18 AM »
Quote from: 3bvert;76905
really ?
I can't remember what the specific resistance spec are for each, but they're listed in the Bentley. Just use a multimeter on the connectors
3bvert
« Reply #11 on: August 15, 2009, 09:32:29 PM »
so is this a problem when installing the cop conversion. I should have all my parts by wednesday to install, would just like a heads up
KenC
« Reply #12 on: August 15, 2009, 10:31:46 PM »
No, not an issue with the COP kit at all! :)
3bvert
« Reply #13 on: August 17, 2009, 10:32:57 PM »
thanks
still waiting on my kit, got the shipping info today on the last of the stuff I need :D
Matt-B
  • Administratorz
« Reply #14 on: August 18, 2009, 01:22:42 AM »
got mine in!!!
-mA+t B
