Author Topic: Rear seat removal e30  (Read 4051 times)
Jorgeconrico
« on: August 01, 2009, 12:09:29 PM »
I can't get the rear back rest out. The bench just popped out. Are there bolts that I'm missing?
1991 E30 M42
« Reply #1 on: August 01, 2009, 02:32:33 PM »
There are two bolts at the bottom corners, one on each side. Once you take those out, pull up on the back rest which will release it from the clips then it should come right out.
romeomike
« Reply #2 on: August 01, 2009, 02:32:41 PM »
Down on the bottom on each side should be a metal strap. Follow it to the end and you should locate a 10mm bolt if I remember properly.
Here's a picture of my old gray cloth seat back showing the metal strap.
Jorgeconrico
« Reply #3 on: August 01, 2009, 02:48:54 PM »
Thanks guys, i had to pull a little bit of fabric away to see the bolts.
