Author Topic: A "what's it worth" thread. . .  (Read 2041 times)
strad
« on: July 31, 2009, 03:51:01 PM »
The 318i is not for sale yet.  But it will be in about 3 months, once I get my 535i into Nevada (it's in CA right now being given some TLC).  Here's the writeup I'm working on:
I have owned this vehicle since January of 2007, when I purchased it with 190k miles.  It currently has 210k miles on the original driveline.  It has a clean title and an extensive collection of service records going all the way back to February 1991 when it was delivered by Chaisson Motorcars (now Desert BMW) in Las Vegas to a lessee.  According to the service records, it has spent its entire life in southern Nevada and southern California, and has had six owners, including me.  It has central locking, AC (converted to R134a by BMW, sometime before I bought it) and manual sunroof.  It comes with two original master keys as well as the original valet key and an owner’s manual.  In December 2007 it was repainted brillantrot (original color).  In December 2008 I purchased new BFG Traction T/A tires for it.  It also has new brakes all around.  I’m in need of more interior space and have purchased a 1991 535i to replace the E30, so it’s on to that project.  Feel free to ask questions or come out to look it over or take a test drive.  This car has been well cared for, is enthusiast owned and maintained, and I’d love to see it go to someone who will care for it in a similar fashion.   It runs very well and has not failed me yet.  In my experience, it gets 24 mpg city and 30 mpg hwy.
Things I have done:
Brakes: Rebuilt calipers, new master cylinder, new brake hoses on front.  New rotors and           pads.  Had new hoses for rear, but upon inspection the ones already on there appear fine.
Cooling system: replaced all hoses, replaced water pump, replaced thermostat.
Vacuum system: replaced all hoses, cleaned intake manifold, replaced all gaskets.
OBC: replaced six-button with 13 button.  Install included stalk and correct coding plug, but did not include any of the components required for the “code” feature.
Tires: replaced in December 2008 with BFG Traction T/A 195/65/14
Paint: new paint in December 2007.  I prepped it, father in law repaired a bent valance,        friend of his painted the car in a downdraft paint booth.  Car has not been color sanded, so some improvement is possible.  Looks good though.
Fluids: have done all at least once, along with filters where applicable.  All driveline fluids are synthetic.  Engine oil gets done every 4k miles or so (Castrol Syntec 20W50), trans has been done twice (Redline D4 ATF).  Rear end is Mobil 1.
Alternator: stopped charging the battery earlier this year.  I found that the brushes were worn out.  Replaced them and it works fine again.
Steering rack: was done immediately before I purchased the car (have records).  I believe they used a rebuilt unit.  It does not leak at any rate.
Control arms: I replaced them in 2007 because of worn-out ball joints.  Install included new oem bushings.  I did not have it aligned afterwards.  It tracks straight and shows no abnormal tire wear but could probably use an alignment.
Motor and trans mounts: all replaced, motor mounts are oem, not sure about trans mounts
Timing chain tensioner: replaced in 2007.  I have also inspected the pan for pieces of timing chain, rail or  anything else twice, at 191k miles and again at about 200k miles.  Both times there were none.
Link to slideshow: http://s829.photobucket.com/albums/zz212/mgheffner/?albumview=slideshow
edit: what I'm looking for is a ballpark price that you, or someone like you, would be willing to pay.  I know what kbb is for it, but that may or may not be the best number to start from lol.
« Last Edit: August 01, 2009, 12:17:44 PM by strad »
