Author Topic: 91 318is Differntial?  (Read 2406 times)
laernu
« on: July 27, 2009, 05:19:35 PM »
I wanted to know for sure what Differntial does a Stock 91 318is come with?
-For some reason i read awhile back that it had a 4.10, but i think i might have read it wrong, if someone could correct me on that... :D
Thanks,
-Mike
Wizard
« Reply #1 on: July 27, 2009, 07:12:25 PM »
91 318is's came with a 4.10 standard....The LSD was an option. Both OPEN and LSD dif's were 4.10
laernu
« Reply #2 on: July 28, 2009, 12:21:24 AM »
how would i know if its a LSD?
manydubs
« Reply #3 on: July 28, 2009, 02:43:45 PM »
Jack up both rear wheels and spin them, if both spin the same direction then LSD..
« Reply #4 on: July 28, 2009, 04:02:25 PM »
You can also look at the metal tag.  If it says 's4.10', you're LSD.  They also usually have a large 'S' painted on top of the case.  Hard to see unless you've pulled it.  It might be worn out regardless, the magic doesn't last forever.
