Now for the "new" wiring harness with all unnecessary items removed.
Just me:
Me holding wiring harness, instrument cluster, ABS computer, and fuse and relay box:
191.1-171.7=19.4lbs
So 19.4 pounds now vs. the 27.4+ pounds before
So probably around 10 lbs in wiring removed when I include all the speaker, radio, and antenna wiring that I left out. Hopefully this will get me a little bit closer to my 2000 pound goal for this car.
Today comes the real test. Putting power to the wiring tomorrow and seeing if all the lighting and stuff like electric windows still work... :eek:
And here is some engine stuff I have planned.
Stock cooling system setup:
My cooling system setup(well, the heater core hoses are just going to be looped):
Stock vacuum system setup:
My vacuum system setup(vacuum lines obviously aren't all going to be T'ed together):
I'm amazed. This is my first time powering up the car, and for the most part, everything runs just fine.
My wiring harness thinning didn't kill the lighting at least. :rofl: First time turning on the high beams and low beams.
even the license plate light works:
Night time lights and turn indicator works:
Third brake light works:
Here is the light control module, with working control illuimation and dimming:
Brake pad sensors, hand brake, turn indicator/hazzards, high beam, and even the service interval counter work:
woot, working hazzard button:
my tail lights work!
well, one tail light works. I need to replace the other, lol.
Interior as it sits right now. Wiring harness is going to be removed again for wrapping so that's why it is only loosely lying about. Sound deadening inside the car has also been removed. I just need to find something to clean up the last little bits to make everything nice and clean.
Only thing I messed up on to my knowledge are the electric mirrors. Apparently I removed the power wire. They still have all the control wires, and ground wires, just no power going to them... I'm not sure on whether I should keep the electric ones or find something manual. If I did find manually adjustable mirrors, this would eliminate the last bit of wiring going to my doors.
The sunroof was removed today as well. The brackets and what not are going to be cut and removed as well, and the hole plugged up with either the old sunroof welded in or a carbon fiber plug glued in, bondo'ed smooth, and painted.
