Author Topic: Engine Compression Figures?  (Read 2218 times)
Serge
« on: July 24, 2009, 12:03:18 AM »
Just did a compression test on my m42 and all cylinders showing 180psi, is that a good or a bad reading, what is the factory spec? cheers.
phrunt
« Reply #1 on: August 05, 2009, 08:50:17 PM »
Normal Compression is 142-156 psi, cylinders should not differ more than 7 psi. The reason for your high readings may have to do with the temperature of the engine, take the reading when the engine is slightly warm, about a quarter way down the temp gauge.
bbarnumboy
« Reply #2 on: August 20, 2009, 05:05:58 PM »
142-156?   wow i just did a head job on mine and used the stock thickness head gasket etc. and with the engine slightly warm i just blew a 215 on 2 cyl and a 220 on 2 cyl  anyone explainw hy it is so high?  before the head job i blew a 200 180 190 and a 90....the 90 was because of a cracked head.  ad now after the had job it is  215 215 220 220
JP 91iS
« Reply #3 on: August 20, 2009, 06:45:09 PM »
Mine were 220 across all 4.  I searched and most people were showing 180 and above so that lead me to believe that the figures listed in the Bentley are the lowest acceptable numbers.
-JP
Project M42: generating funds
