Sean_318is
Author Topic: Sean_318is  (Read 15677 times)
Sean_318is
Sean_318is
« Reply #30 on: February 02, 2010, 04:12:25 AM »
I've found a silver bonnet from the local breakers, £50 :)
But it's for a saloon :( It won't fit, no heater grille space
« Last Edit: February 02, 2010, 08:28:54 AM by Sean_318is »
1994 BMW 318is Coupe
Sean_318is
Sean_318is
« Reply #31 on: February 03, 2010, 04:47:23 AM »
Today I'm swapping the silver saloon bonnet for a black coupe item for the 320i. Should look interesting hehehe. Shame I can't afford the headlamps and front grille too, then it would be finished by next week....
and here it is:
« Last Edit: February 03, 2010, 07:15:13 AM by Sean_318is »
Romrog318is
Sean_318is
« Reply #32 on: February 03, 2010, 07:57:09 AM »
looks pretty good!
i also have a few sets of 5 1/4 speakers if your interested...
no more M42
Sean_318is
« Reply #33 on: February 03, 2010, 08:37:39 AM »
Seems a bit tight for that rad fan, eh?  You must have needed a really thin wrench/spanner.
Sean_318is
Sean_318is
« Reply #34 on: February 03, 2010, 11:37:51 AM »
Quote from: DesktopDave;86574
LOL :) I had to strip the front off first to get to the fan! I got a new one for £10 :)
Quote
looks pretty good!
Thanks for the offer but I don't really need any :)
« Last Edit: February 04, 2010, 02:29:24 AM by Sean_318is »
Romrog318is
Sean_318is
« Reply #35 on: February 03, 2010, 05:03:51 PM »
i just read that you already got some lol
GOOD LUCK with it
no more M42
Sean_318is
Sean_318is
« Reply #36 on: February 04, 2010, 02:35:02 AM »
Thanks, I'm going to nick the door lock from it for my iS. I'll be bolting the bonnet on today during my lunch break :)
Sean_318is
Sean_318is
« Reply #37 on: February 04, 2010, 09:01:51 AM »
Here's todays efforts, not bad for an hour!
Slam panel fitted with bonnet:
Sean_318is
Sean_318is
« Reply #38 on: February 08, 2010, 05:52:59 AM »
Tinted Rear Lamps:
Had a go with the rear lamps this weekend, I'll fit them to my car to see what they look like.
Sean_318is
Sean_318is
« Reply #39 on: February 16, 2010, 08:30:51 AM »
13/02/10 - My 318 gets an Engine flush and oil and filter change (5w/30) with oil system protector :) Then the next day I drove it 250 miles on motorway and twisty bits just for fun :) hmmm redlined it a couple of times too.
Seems to run better now. Got a pretty bad oil leak from the timing cover area though, and before I changed the oil it had white gunk on the filler cap and dipstick :S
« Last Edit: February 16, 2010, 08:32:58 AM by Sean_318is »
Jorgeconrico
Sean_318is
« Reply #40 on: February 16, 2010, 01:55:47 PM »
White gunk on the oil cap and dipstick is scary stuff dude.....
Sean_318is
Sean_318is
« Reply #41 on: February 17, 2010, 10:53:41 AM »
Yeah I know :( , I'm thinking about changing the head gasket & timing chain etc later on this year.
I've planned two holidays this year (Sardinia and Arizona/Nevada) so my funds are already commited.
Sean_318is
Sean_318is
« Reply #42 on: February 18, 2010, 06:34:55 AM »
Ordered a replacement RH door latch from ebay 2 days ago (£15) which arrived this morning :) Hopefully it will fix the central locking/window closure problem. Any other suggestions welcome! The remote CL no longer works and the window doesn't pop up into the seal when I shut the door...
Sean_318is
Sean_318is
« Reply #43 on: February 23, 2010, 04:53:28 AM »
So, fitted the door latch, didn't fix the window problem - it's activated by the pin switch in in the striker. Also the latch was wired different from mine, even though it was from the same year car! It worked but didn't lock from the inside when I pushed the nob down.
In the process I broke the door handle at the usual place, the crappy aluminium snaps the actuating rod off :(
Anyone swap a latch for a handle and key? :S
Sean_318is
Sean_318is
« Reply #44 on: February 25, 2010, 11:24:08 AM »
New washer bottle for the 320 on the way, eBay £5.49 :)
