Sean_318is
Author Topic: Sean_318is  (Read 15706 times)
Sean_318is
Sean_318is
« Reply #15 on: August 11, 2009, 07:53:25 AM »
Yeah your losing 30 odd % :( Same with sterling.
Petrol is about 1.09 per litre locally, so about $1.79/L or E1.29/L.
1994 BMW 318is Coupe
Sean_318is
Sean_318is
« Reply #16 on: August 18, 2009, 03:58:42 AM »
Update:- I've now replaced the leaky cam cover gasket :) Hopefully it wont leak any more, but when I change seals I tend to make things worse!
I'll re-tighten the bolts tonight and check for leaks.
Sean_318is
Sean_318is
« Reply #17 on: August 20, 2009, 03:20:27 AM »
Well the top isn't leaking anymore, but I can see a leak from the bottom somewhere. gonna check the timing gasket and sump. Payday next week, then I can get a door handle :) and I can start on the fun stuff like start buttons, spoilers and bodywork!
« Last Edit: August 20, 2009, 03:22:52 AM by Sean_318is »
Sean_318is
Sean_318is
« Reply #18 on: August 25, 2009, 06:05:45 AM »
Recieved my K&N Filter cleaning kit on 21/08 :) Fast delivery from a seller on eBay!
I cleaned and re-oiled the filter and the difference is noticable, better throttle response and more growl.
Next I need a new alternator because it just isn't properly charging the battery! After 1-2 days parked its drained.
Sean_318is
Sean_318is
« Reply #19 on: August 25, 2009, 06:20:28 AM »
Sean_318is
Sean_318is
« Reply #20 on: September 01, 2009, 07:35:04 AM »
New alternator fitted, everythings fine for now :) A bit more power in the engine it seems
Vladi
    • http://www.bmwzone.ro/forum
Sean_318is
« Reply #21 on: September 01, 2009, 04:45:28 PM »
Better voltage, better spark. ;)
Sean_318is
Sean_318is
« Reply #22 on: October 14, 2009, 04:48:18 AM »
:) I've now got some nice footwell lighting courtesy of 2 Blue LED strip lamps wired into the clock feed.
Sean_318is
Sean_318is
« Reply #23 on: October 19, 2009, 06:45:13 AM »
This months updates, I've tinted the front indicator lenses to match the dark headlamps and I'm in the process of painting and fitting lower headlamp eyelids/brows :)
« Last Edit: October 19, 2009, 07:01:49 AM by Sean_318is »
Sean_318is
Sean_318is
« Reply #24 on: October 22, 2009, 03:41:33 AM »
Ordered a new cam cover breather hose today, the old one feels like jelly and is all blocked up £18.60 trade price
Sean_318is
Sean_318is
« Reply #25 on: November 04, 2009, 06:22:42 AM »
The LH door handle arrived last week, £27 from eBay. I fitted it on Saturday and I'm now enjoying the novelty of opening the passenger door from the outside! :P
Breather hose also replaced and headlamp eyebrows painted and fitted. :)
Yesterday I replaced the front speakers (well, they were missing when I bought the car!) with some 5.25" Pioneer units. Much fuller sound now.
http://i760.photobucket.com/albums/xx246/sean_E36318is/bmweyelids.jpg
« Last Edit: November 05, 2009, 04:44:59 AM by Sean_318is »
Sean_318is
Sean_318is
« Reply #26 on: January 13, 2010, 05:26:13 AM »
So far these past two months or so:
Replaced front passenger window and rear drivers side window after smashing to get into the car, after it locked the keys in it twice! £100 :(
Replaced the spark plugs and so far cured the misfire around 2500 rpm. Free plugs ;)
Now my drivers window has decided its not going to work properly (no drop down/auto up) when I open the door and the remote central locking is on the fritz! yay!
Sean_318is
Sean_318is
« Reply #27 on: January 21, 2010, 06:35:42 AM »
(spam)
« Last Edit: February 04, 2010, 02:42:54 AM by Sean_318is »
Sean_318is
Sean_318is
« Reply #28 on: January 27, 2010, 07:40:33 AM »
My new donor car, tho its a 320I
« Last Edit: February 01, 2010, 05:51:42 AM by Sean_318is »
Sean_318is
Sean_318is
« Reply #29 on: February 01, 2010, 06:32:23 AM »
"It'll polish out" ;)
