Author Topic: Overheating Please Help  (Read 2617 times)
Serge
« on: July 22, 2009, 01:05:22 AM »
I have replaced the bloody head gasket, new gaskets all round etc... the car overheat when idling, no white smoke nothing at all, I noticed when I rev the bugger the needle drops back to centre, bring it back to idle and the needle pegs up... I have a new thermostat, belts and water pump, with new hoses the whole 9 yards... obviously the coolant isn't circulating properly or fast enough... any input would be great. Sere.
romeomike
« Reply #1 on: July 22, 2009, 06:50:48 PM »
Replace the fan clutch. You could also run the AC as that would trigger the aux fan to run.
318lotis
« Reply #2 on: July 22, 2009, 06:59:04 PM »
you can test the fan with a rolled up newspaper, if you can stop the fan with a rolled up newspaper, it needs to be replaced. just be carefull.
nickmpower
« Reply #3 on: July 22, 2009, 08:41:34 PM »
does it instantly rise when you rev? did you have your head pressure tested? are you loosing coolant?
monty23psk
  • -Receive: 17
« Reply #4 on: July 22, 2009, 08:58:31 PM »
make sure to bleed it all the way.
Serge
« Reply #5 on: July 23, 2009, 12:18:27 AM »
when I rev the temp needle falls back to normal... I had the head pressure tested and machined, will hunt down a new fan clutch and keep posted, thanks for the suggestion this has go me stumped.
« Last Edit: July 23, 2009, 06:40:09 AM by Serge »
