Author Topic: Standard Replacement/Upgrades  (Read 3463 times)
kevins08
« on: July 21, 2009, 09:18:17 PM »
I now have my turbo project motor all torn down and am awaiting the lower cr pistons, so in the mean time what should i do? What are some of the standard replacements and upgrades that i should do while i have the engine torn apart. I know about the bearings, but im sure there are more things as well. I have the obdI m42 from a 1994 bmw 318is. This also might be a good sticky for people in the future with their engines torn down. It would be a good place to go to find everthing in one spot.
kevins08
« Reply #1 on: July 28, 2009, 06:26:08 PM »
nothing eh? our motors are that wel built from the factory?
rob_e30
« Reply #2 on: July 29, 2009, 01:24:08 AM »
I would recommend upgrading to ARP studs and replacing all of the timing guides and sprockets but these motors are pretty solid.
ApocolypseAutoEngineering
« Reply #3 on: July 30, 2009, 04:28:49 PM »
Depending on how many miles you have replace the front and rear main engine seals. If they are old they could start to leak under boost.
E30 FOR LIFE!!!!
rob_e30
« Reply #4 on: July 30, 2009, 08:42:51 PM »
Quote from: ApocolypseAutoEngineering;76079
I assumed that was a given, but good point.  It's also a good time to chase all the threads and make sure that none of the timing cover or oil pan threads are stripped.
Rob.
kevins08
« Reply #5 on: July 31, 2009, 12:42:00 AM »
twas a given, but still a valid point.
