Installed a volvo electric fan over the weekend and blew the low speed fuse (15A) in the process. Replaced with a 30A fuse and it was fine. Worked on car for rest of day and now it will not turn over and some electronics do not work.
Symptoms:
Car won't turn over (starter does not even click)
Red battery light on dash not working
Brake lining light gets bright when key is in start position
Power windows don't work
Electric fan doesn't work
Interior blower doesn't work
Fog lights don't work
Power mirrors don't work
All other lights work, radio works, OBC works, power locks work
I thought the problem were some relays, K5 and K7 since they are connected to the starter and most of the other electronics that are not working go through them. I replaced them and still have the same problem. One of the relays I tried in K5 ended up making the power windows work all the time, even without the key in the ignition.
With all the K relays removed, the battery light (red) on the dash faintly lights up. When I put a relay in K5 or K7 the battery light gets so faint it's hard to see.
Anybody have any ideas on what is wrong with my car? I haven't tried to roll start the car because if it doesn't start I can't get the car back into my driveway since my street is downhill.
I am getting battery voltage at the power distribution on the firewall on the passenger side and at the main connection on the fuse box circuit board. Most fuses are getting power except for the ones relating to the electronics that do not work. I can't figure out what is going on (or not working).
