Author Topic: Melted metal and missing spring  (Read 1989 times)
seph429
« on: July 19, 2009, 04:22:31 PM »
Alright so in the process of replacing the rear main seal i get the flywheel off and there is metal in one of the bolt holes. the flywheel itself has an indentation in the matching spot. can i just clean it up and it should be okay?
also, in the parts of the clutch there is a spring (#6 in the picture) that was not there when i took it apart, is it important?
http://www.realoem.com/bmw/showparts.do?model=AF93&mospid=47305&btnr=21_0020&hg=21&fg=05
thanks for the help still kind of new to all this
e30guydownunder
« Reply #1 on: July 19, 2009, 08:39:57 PM »
#6 holds the clutch fork on the pivot point, it is fairly important, whilst not necessary if everything is correct, but as you have it apart i would replace it purely for peace of mind. Basically if the clutch fork does fall off the pivot you will have to pull the tranny to fix it.
nickmpower
« Reply #2 on: July 22, 2009, 01:38:58 AM »
that metal sleeve is supposed to be there to align the flywheel
