Author Topic: fuel pump suggestion  (Read 3286 times)
l4u5k4e
« on: July 15, 2009, 03:58:52 AM »
hi, i need a bigger fuel pump for my e36, can any one suggest a bosch or walbro pump that will fit? i was going to get a bosch 044 pump but not sure if it will fit, has anyone upgraded this before?
ps. i have been told walbros are smaller in size, will it fit in better than a bosch?
thanks
HATER-PROOF
« Reply #1 on: July 15, 2009, 04:18:21 AM »
Hi-If I may ask, for what reason are you trying to upgrade your fuel pump?, because you may have to upgrade not just the pump depending on your set-up.
l4u5k4e
« Reply #2 on: July 15, 2009, 04:30:47 AM »
the start of august a sr20det is getting put in and i will need a bigger pump... plus not to sure if it will start up with the smaller stock bmw pump.
HATER-PROOF
« Reply #3 on: July 15, 2009, 08:18:39 AM »
OOOOOOHHHH!!!! I see that you're not playing around--$$$$ the only thing I could tell you is to call or email these guy's with your exact questions, because with that type of set-up you want to be sure that your money will be spent wisely.
This brand new, GENUINE WALBRO 255LPH High Pressure External In-line fuel pump can support over 500hp (at the crank) when supplied with 13.5V!
REperformance Inc.
1733 Monrovia Ave. Suite X
Costa Mesa, CA 92627
760-586-5617
Fax: 714-907-0863
GSL-392 255 LPH Fuel Pump and one 400-939 installation kit.  I would be a proud daddy after all of that work is done.
l4u5k4e
« Reply #4 on: July 16, 2009, 02:18:04 AM »
thanks mate, i'm also going to try a guy tomorrow who specializes in performance bmw's and tell him my situation, hopefully work out what i need.
