Installed but no start
Well it starts but sounds like its down a cylinder or two. It'll run for like 10 seconds and fight to keep running but eventually dies out.
I'm pretty sure I got all the coils plugged into the right lead, my only though is that the coils arent fully seated on the spark plug, even though I had them screwed all the way down.
Any suggestions? I might just try re-installing the whole thing and if that doesnt work then I'll file down one of the plastic spacers and see if the coil will seat better on all the plugs.
Hopefully I don't have a bad coil.
Also, when you all are installing the coils, do you plug them into the right leads before screwing them down? Is it possible to get them connected once they are all seated?
