Author Topic: Fuel Injector Removal Help  (Read 4999 times)
CePa318IS
« on: July 04, 2009, 03:39:06 PM »
Hey guys,
I am trying to remove my fuel injectors from my lower intanke manifold and fuel rail.  Here is what I have.  How do I remove those basterds?  Any help is appreciated.  ~Scott
Bunta
« Reply #1 on: July 04, 2009, 04:08:40 PM »
pull on them.
There really stuck on there,  the seals fit super snug.
I actually had to use a pry bar then they pop off.
Hutner
93bmw318i
« Reply #2 on: July 04, 2009, 05:30:03 PM »
pull the clips under the rail top side of injector and then pull pull pull hard have fun..
CePa318IS
« Reply #3 on: July 04, 2009, 08:34:52 PM »
I put a little wd40 around the seals to loosen things up.  I let it sit for about 10 minutes, then I pulled with all my might.  Once one side came out, the rest was easy.
Thanks again guys!
Scott
DesertEagle
« Reply #4 on: May 21, 2010, 05:17:02 PM »
I let wd-40 soak in as suggested above.  Then I used an 16 mm open wrench as a lever under each fuel injector.  I used the lower intake manifold as my fulcrum and lightly tapped on the other end of the wrench to pop up each injector.  Worked well.
PumpItUp
Question about fuel rail
« Reply #5 on: May 27, 2010, 01:31:06 AM »
Alright serious question here. no more dumbrarse questions from working on the car in the dark
on the lower intake manifold, in the fuel ports, 1mm above the injector's lower o-ring, there is round engraving like its meant for a washer, like the paper washer for the radiator temperature switch. is that supposed to be void of anything? although the most probable cause of a fuel leak seems to be those cheap black clips for the top o-ring.
« Last Edit: May 28, 2010, 06:34:19 PM by PumpItUp »
DesertEagle
« Reply #6 on: May 28, 2010, 08:40:12 PM »
Quote from: PumpItUp;92952
i haven't reinstalled my fuel rail yet, but if I remember correctly when I removed it, those cutouts are where the fuel injector electrical connector extends towards the black plastic rectangle that contains the wiring.  Mine are void of anything.  I'm not sure of the purpose of the cutout, but it may allow air to circulate between the fuel injector and the lower manifold.
Is it a dumbarse question to ask why you don't buy a light if you work on your car after dark?
