Author Topic: Verification that a 3.5 bar FPR wont run right on the M42?  (Read 2480 times)
JoeDellio
« on: July 01, 2009, 03:52:48 PM »
I got sent the wrong one, but I threw it in just to test things. I cant smell any fuel or anything, but since its suppose to have a 3.0 bar FPR am I inviting trouble?
Stupid question?
[SIGPIC][/SIGPIC]1995 318i
1991 E30 M42
« Reply #1 on: July 02, 2009, 02:35:03 AM »
it will work just fine once the ecu adapts
JoeDellio
« Reply #2 on: July 02, 2009, 03:43:06 AM »
cool, thanks. I was thinking it would just fire the injectors normal, but with a higher pressure they would dump more fuel.
Deftones
« Reply #3 on: July 02, 2009, 01:41:38 PM »
if you disconnect the O2 sensor it will do so
http://blogs.yahoo.co.jp/luca318is
1992 318is e36
1990 318is e30
JoeDellio
« Reply #4 on: July 02, 2009, 06:01:15 PM »
Quote from: Deftones;74709
What do u mean? If I disconnect the O2 it will adjust to it? Im not sure what you meant. Can you please clarify that for me?
B318M42W
« Reply #5 on: July 02, 2009, 10:59:54 PM »
the O2 sensor will tell the ECU to rich/lean the mixture. so if you disconnect the O2 sensor, the ECU won't be able to adapt to it and you will send fuel into your exaust...
M90 Blown M42 :cool:
JoeDellio
« Reply #6 on: July 03, 2009, 02:07:23 AM »
Quote from: B318M42W;74736
ah, ok, I didnt know that he meant that.
I should maybe try looking into O2 sensor electrically.
What ways could I test the sensor and the harness themselves? My car is running pig rich as if it was dead or unplugged.
