Author Topic: Clutch adjustment  (Read 2578 times)
Windsma
Clutch adjustment
« on: June 29, 2009, 08:58:45 PM »
I was under the impression that my clutch was slipping.
With the way i drive my foot is always on the clutch pedal. I noticed that there is pressure from my foot resting on the pedal.
So i dove it with my foot completely off and it was a little different.
Is there an adjustment that will allow me to have < 1/2 inch of travel before the clutch disengages?
94 318is 5spd 200k
JP 91iS
Clutch adjustment
« Reply #1 on: June 30, 2009, 01:16:34 PM »
Don't drive with your foot on the clutch pedal.
-JP
Project M42: generating funds
Clutch adjustment
« Reply #2 on: June 30, 2009, 02:04:00 PM »
There should be about 1/2" of 'wiggle room' on the clutch pedal.  If you pull the lower trim piece from under the steering column you'll see what I mean.  While you're in there check for leaks off the windshield & plenum.
Definitely stay off that pedal unless you're shifting.  You'll wear out the cylinder seals & the throw-out bearing.
« Last Edit: June 30, 2009, 02:08:05 PM by DesktopDave »
Windsma
Clutch adjustment
« Reply #3 on: June 30, 2009, 02:52:21 PM »
Ill try harder to be aware of it.
After driving a manual for 12 yrs its kinda difficult. I dont miss my non/hydro clutch.
94 318is 5spd 200k
