oil temp too high
Author Topic: oil temp too high  (Read 2670 times)
Deftones
oil temp too high
« on: June 28, 2009, 05:10:39 PM »
hi everybody, this evening coming home with my car was raining and i did some drifts, nothing special, just few seconds to 6000rpm... the problem is that then on my oil temp gauge i saw the temperature was gone up bouncing from 102 to 107 °C, then after a few minutes, when i was going very slow the oil goes up to 120°C...
normally in highway at 3500rpm is stable at 100°C, and the gauge is not bkoken because when the oil comes hot the pressure gots down (i have also a pressure gauge). It's lotta strange because the water temp is good in both sides of the engine (approx 90°C?
anyone got ideas?
http://blogs.yahoo.co.jp/luca318is
1992 318is e36
1990 318is e30
1991 E30 M42
oil temp too high
« Reply #1 on: June 29, 2009, 01:25:48 AM »
Doesn't sound too out of the ordinary, my temp sits around 180*F once its good and warmed up and I'm cruising, and will go up to almost 240*F when I'm getting on it hard.
Deftones
oil temp too high
« Reply #2 on: June 29, 2009, 06:27:17 AM »
well it's not ordinary, because the car didn't do it before! even when i pulled hard it never goes up to 115°C (like the 240°F you said) , so i'm worried because yesterday i don't get that hard, just a few times to 6000rpm!
what i wanna know is why the oil goes that hot! is a main bearings or a piston rings problem? if so it's very very bad
1992 318is e36
1990 318is e30
oil temp too high
« Reply #3 on: June 29, 2009, 06:59:49 AM »
I should slap a gauge on the car...I have not idea what temp it gets to, but 120 DegC doesn't seem too high.
Deftones
oil temp too high
« Reply #4 on: June 29, 2009, 09:15:18 AM »
i've turned on the car just now, it shows 40°C at a real temp of 23°C... the gauge is totally gone! maybe the oil pressure was a bit low but not low enought to justify 120°! that has been my mistake!
1992 318is e36
1990 318is e30
