Author Topic: Bleed screw (radiator) leak help PLEASE  (Read 4098 times)
melloh
« on: June 22, 2009, 01:41:19 PM »
Hello, all.  I've spent the last 2 weeks working on this car only to have a leaking radiator bleed screw keeping the car off the road.
Simply put, it is leaking through the bleed screw.
I just replaced with a new screw ($8 from dealer!!) and it is still leaking.
I looked in and poked around to see if there were any obstructions - nothing.
I do not know what the anatomy is supposed to look like, so I will describe what I discovered.
In the middle of the hole, there is a metal(?) tube (like 1cm dia.) surrounded by plastic.  However, for about 1/3 of the circumferance around the metal tube, there is NO plastic (I could stick a toothpick all the eay through).  Is this correct???
So, I am curious what my options are.  Obviously, I want to avoid buying a new rad.  Hopefully I get some feedback soon or I will have to give up aand take it to a mechanic.... I need my car back!
Thanks in advance.
« Last Edit: June 22, 2009, 01:45:01 PM by melloh »
« Reply #1 on: June 22, 2009, 02:10:23 PM »
I can go take a look at mine...but I have to admit I'm a little bit afraid of breaking it.
melloh
« Reply #2 on: June 22, 2009, 02:25:29 PM »
Thanks, Dave.  I'd appreciate it.  IF I need to replace the whole thing, I'm wondering if it is possble to 'bandaid' it until the next time I need to flush (hopefully I can afford a new rad then) by putting RTV sealant on the bleed screw?  I know this is not optimal, but if it works, it'll have to do.
B318M42W
« Reply #3 on: June 22, 2009, 05:30:00 PM »
or might want to try and find a suitable sized O-ring instead of the RTV???
M90 Blown M42 :cool:
CCR Engineering
« Reply #4 on: June 22, 2009, 05:53:23 PM »
I had that problem before.  On mine the plastic around the threads was cracked.  Once that happens no o-ring is going to work, you have to replace the radiator.
melloh
« Reply #5 on: June 22, 2009, 06:27:41 PM »
Crud.... ha ha.  That's what I assumed.  Any brand suggestions?  I'm looking at the Behr from Pelican (157.25).  The only other option is the Nissens or Valeo from thepartsbin.com.  I'm ordering the Behr.
The biggest kickers are:
1) I have to drain it again.. another $15 worht of radiator fluid and water wetter (I know it can be reused, but I don't trust the cleanliness of my bucket)
and
2) I had spent a good 4 hours with a plastic toothpick straighening fins and digging out pebbles, bugs, hairs, newspapers, etc... ACK!  What a waste.
Thanks for the quick replies, all.
PS:  I assume the toothpick was NOT supposed to be able to go through, right?  It's supposed to be solid plastic around that little tube?
rx82000
« Reply #6 on: June 22, 2009, 06:40:58 PM »
I got the same issue. The threads on the radiator are gone.
I used "teflon tape", i.e. the stuff you put on the threads for plumbling, around the bleed screw and it fixed the leak.
I got it in there and its not leaking. I might try the re-tap the radiator when I need to get it out.
They sell a Brass one on bimmerspecialist.
« Reply #7 on: June 22, 2009, 07:11:12 PM »
I tried to get mine out, but it's stuck a little too hard.  With all these stories of new radiator I have to admit I'm being cautious with this one...but I did the next best thing, found a picture slideshow:
http://www.ecstuning.com/BMW-E46-323i-M52_2.5l/Engine/Cooling/ES10888/
rx82000
« Reply #8 on: June 22, 2009, 11:15:09 PM »
