When baby (and the E46) came, I parked my M42 for a while since it needed driveline work that I didnt have time to do. That was 3-4 months ago. Now that its 95+ deg outside and 95% humidity, I feel I need to pay it some attention.
There is what I am guessing a valve train tick that does not go away. If it sat for a few days previously there would be chair whir on startup, but only for a few seconds before the oil fully circulated. Now the tick does not go away after a few seconds; it is persistant on several starts.
I did a lot to the motor before I parked it: new plugs, compression test (185-190 on each cylinder), new valve cover gasket, cleaned the intake manifolds, mustang injectors, throttle body delete, new vacuum hpses, new icv, cleaned maf.
Any ideas on things I can check? It is not throwing any codes. I have not run the motor longer than a minute at a time. Semi-fresh Syntec 10w40 in it now.
