Author Topic: E36 M3 calipers to fit on E36 318iS discs?  (Read 3153 times)
M42_Jester
« on: June 19, 2009, 06:05:38 AM »
Does anyone know if the M3 brake calipers will fit on the stock 318iS (E36) discs? is it as simple as just taking them off an M3, and putting them on the other discs...or am i just thinking that it is?
Cheers,
Jester
HoJo Ti
« Reply #1 on: June 19, 2009, 06:11:32 PM »
Not that simple, the caliper typically won't bolt up to the knuckle. As for the disc, if you were to use an M3 caliper with a 318 disc only half of the pad would actually touch the disc, the rest would be too far out.
Won't work
M42_Jester
« Reply #2 on: June 19, 2009, 10:15:35 PM »
that wat i thought...
but would a set of M3 brakes (calipers, discs, rotors etc.) fit onto a 318iS?
Boosted E30
« Reply #3 on: June 20, 2009, 09:29:18 AM »
you would have to use the m3 knuckle with hub rotor caliper and pads then it would work.
M42_Jester
« Reply #4 on: June 20, 2009, 10:38:26 PM »
cheers for that mate.
least i know where i hav to start now...
anyone know how much a set of E36 M3 brakes (rotors, calipers, discs etc) would set me back?
DLag30
« Reply #5 on: June 20, 2009, 10:55:54 PM »
you might want to check this thread out:
http://www.318ti.org/forum/showthread.php?t=24547
