Author Topic: Axle Lengths  (Read 2879 times)
M42boy
Axle Lengths
« on: July 23, 2006, 10:49:37 PM »
Okay, so I had to replace both rear half-shafts on my 318iS (the axles), so I went to the yard.  I asked if he had any for a '91 318iS...   Bobby at Strictly German said that while the stock 318 half-shafts may work fine on this car, they are actually longer than those on a 325, and since I'm running a medium case differential out of a 325 auto, I should run the appropriate 325 axles.
I wouldn't have believed it myself, but he put two side by side and yup, the 318 half shafts are longer!
Anyways, I went up one weekend and got one from a 325iX, and then another out of a 325i cabrio.  When I had them side by side, I realized they two are different lengths!
See picture below.  The upper one is out of a '90 325iX, and the bottom one is out of the same year (I think) 325i cabriolet.
Here's a closup of the ends.
For some reason, I guess the iX one is a little longer.  So, I need to return it and pull the other one out of the cabrio to get a matching set.
Berlin
Axle Lengths
« Reply #1 on: July 24, 2006, 03:21:29 AM »
what, thats crazy, i measured the distance flange to flange on both the medium case and the small case and its the same! look in this pic
http://www.m42club.com/forums/showpost.php?p=6152&postcount=11
e9nine
Axle Lengths
« Reply #2 on: July 24, 2006, 08:08:39 AM »
Ha ha I was just thinking about this issue of yours. Call Bobby and get him to exchange it for you. The iX ones are NOT compatible with non-iX cars. I would assume he would know better that the drivetrain on that unicorn is not the same as all others. We share the same parts as the 325i/m3 and not the iX
Part # 33211226901 is for the ABS equipped cars. G.luck
2002maniac
Axle Lengths
« Reply #3 on: July 24, 2006, 05:20:55 PM »
:confused:
That cant be right.  325e/i/s and 318is axles are identical.  I have an axle off a 325e onmy car at the moment.  It measure exactly the same as the one that came off.
e9nine
Axle Lengths
« Reply #4 on: July 24, 2006, 05:25:04 PM »
Quote from: 2002maniac
:confused:
Yeah in his case he has a 325i and 325iX combo hence the difference. No need to be :confused: everything is kosher ladies and germs :)
M42boy
Axle Lengths
« Reply #5 on: July 26, 2006, 07:54:40 PM »
Quote from: e9nine
You are right!  I did some more investigative work.  The 325's and 318's are indeed the same.
The 325 rear axle is PN#  33 21 1 226 901  (Same as 318iS)
The 325iX rear axle is PN# 33 21 1 225 893
The iX axle is going back for the other 325 axle on Saturday morning. :D
