Author Topic: Head Gasket blew Southeast MO help  (Read 2944 times)
lcgtrplr
« on: June 17, 2009, 10:00:58 PM »
Head Gasket blew 8 hours from home today. A shop pressure tested it and
diagnosed head gasket. Had to rent a truck and trailer to get it home.
I live about 3 hours south of st louis and 3 hours north of memphis about 70 miles west of I55.  I need some recommendations on maybe someone who can do the job. My mechanic has done a lot of suspension work, ac and assorted
other jobs but he doesnt want to tackle the head gasket.
Thanks for any referrals.
Thanks
« Reply #1 on: June 17, 2009, 10:11:39 PM »
You can do it...it's a nuts & bolts job, not too tough...just time-consuming.  We're here for you.
I'd estimate it'd cost you about $150 in gaskets & supplies.  Much more if the head warped.  You're actually saving money...if you can't finish it off, just tow it to a mechanic then.  He'll charge you what it'd normally cost...so even if you fail you're only a little behind the game.
lcgtrplr
« Reply #2 on: June 17, 2009, 10:22:40 PM »
Thanks for quick reply Dave im really thinking about tackling it. I did replace all of the hoses under the intake so im not totally helpless but this is somewhat of a bigger project. The
motor only uses 1 quart between changes and has about 220k on it.
lcgtrplr
« Reply #3 on: June 17, 2009, 10:23:49 PM »
i have put 50k on it in less than 2 years so it has been a little work horse
lcgtrplr
« Reply #4 on: June 17, 2009, 10:25:19 PM »
I really hope they diagnosed me right. Heater does not blow warm even when full. I did
replace thermostat about 2 months ago.
