Author Topic: Can early struts swap with our later ones?  (Read 2777 times)
« on: June 15, 2009, 03:20:54 PM »
I was searching for this...couldn't find it.  Our 51mm struts are wider than the early e30 45mm.  Can they still swap with the early ones if I grab the whole housing?  What difference is there in 5mm?
I found a nice set of bilstein sports in an '86 diving board e30...but I'm suspecting that they won't fit.
Now I'm confused.  I measured my 1991 318i 4-door (build date 8/90) and the struts are about 2".  I'd assume that's the 51mm housing.  When I measure the struts I pulled off my 87 325is parts car, they're the same 2".  Can anyone explain?  Does the early M42 sedan have different struts than the later 318is and 'vert?
« Last Edit: June 15, 2009, 04:31:01 PM by DesktopDave »
tom d
« Reply #1 on: June 15, 2009, 08:23:26 PM »
the struts are interchangeable. i just did this, putting 51mm 318is struts onto a 1984 318 with 45 mm tubes. everything fits, brakes and all, however there might not be a bracket for the abs sensor wire.
the 1987 325is came with 51mm struts.
all M42 318s came with 51mm struts
Tom D
77 e21-m42 powered
88 e30m3
04 e46 330ci
84 r100rt
02 r1150rs
