Author Topic: Help Identify These Bits and Pieces... Pics Included  (Read 2831 times)
Serge
« on: June 07, 2009, 09:02:12 PM »
Greetings from down under, I recently purchased a 1993 318is and need a bit of a hand with identifying a few bits and pieces under the hood and in the cabin, the list is as follows.
1. Loose plug in engine bay, passenger side (RHD)
2. Loose connector with 2 points also passenger side only -
3. Loose connector with 3 points on both passenger and driver sides -
4. Loose wiring running from passenger side wiring loom and runs under the plastic radiator cover to driver side (brown/yellow) -
5. Now I am aware that possibly the 3 prong connectors may of been for the fog lights as they are not connected but the seem to have a different socket-
6. An educated guess tells me that these are the switches for the fog lights... but why are there 2 of them?
7. What is the function of the S.E.M switch next to the shifter?
Now the previous owner has installed a new front bar and angel eyes head lights which may have caused some of the wiring to not be completely utilised..
8. I also have an issue with the left front indicator not working, I have replaced the globe and tried to fit the indicator housing from the left to right and the housing/globe seem to be o.k therefore the problem lies within the wiring?
9. I also have an issue with the wipers working intermittently or on "High", could someone advise whether this is a relay issue or the motor itself?
Any suggestions/clarifications would be highly appreciated. thanks.
Serge.
« Last Edit: June 07, 2009, 09:21:39 PM by Serge »
« Reply #1 on: June 07, 2009, 09:59:24 PM »
That's a good set of riddles there, that's for sure.  If I had to guess (and I do) I'd say that the first one might be the cruise control plug; the others might be for city lights?  As for the other plugs, my US spec e30 and e34 both have little plugs like that in the front quarters.  I have no idea what optional equipment they're for.
I know the one about the light switch...one is front fogs, one is rear.  We don't get them here because, well, I don't know why.
I think the test for the wipers involves pulling the switch and seeing if it has continuity.
The S.E.M. switch is for the transmission mode.  S is Sport, M is manual.
« Last Edit: June 07, 2009, 10:08:39 PM by DesktopDave »
roundel318
« Reply #2 on: June 08, 2009, 03:18:11 PM »
The two pin quick connectors remind me of the 12v lead for the washer pump, they are also used on the two foglamps.
This is on a E30, 91 318i.
LHD
Serge
« Reply #3 on: June 08, 2009, 10:27:31 PM »
thanks for your reply's guys keep em comin :)
