Author Topic: 3 Stupid Questions....  (Read 2653 times)
Blip Bavarian
« on: June 06, 2009, 04:29:30 PM »
i am in the process of swaping hoses, and putting my manifold back on.
1- Is there something that i should put on my gaskets to help them seal?  Or do i just put the new gaskets in dry?
2- How do i make sure that i have bled the coolant lines, and there is no air in the lines??
3- Do i need a torque wrench for the bolts to the manifold and throttle housing, or should i just make sure they are snug?  (i dont have a torque wrench yet)
As always thanks for helping a noob.:D
« Reply #1 on: June 06, 2009, 04:35:08 PM »
Manifold gaskets go on dry.  You could use gasket adhesive but it's not really going to help them seal.
I bleed the coolant with the car parked going up a hill.  Turn the heater on full hot, fill the radiator with coolant (and distilled water if it's not pre-mixed), open the little plastic bleed screw (carefully) next to the radiator cap, turn on the engine and wait for the bubbles to stop coming from the bleeder.  Close the bleeder, fill to final capacity (Kalt? line) and take it out for a short drive.  If you get good heat from the heater (and you don't see any obvious leaks) you should be good to go.
Snug is good for the manifold.  They're only 10mm nuts, right?  I'd go hand tight then 1/8 turn or so.  I use my little 1/4" or 3/8" ratchet for small stuff like that.  Don't go putting them on with a 1/2" impact wrench.
« Last Edit: June 06, 2009, 04:37:25 PM by DesktopDave »
« Reply #2 on: June 06, 2009, 06:01:03 PM »
I used RTV on my intake manifold gaskets. I'm paranoid.
« Reply #3 on: June 06, 2009, 06:20:44 PM »
I HAVE to get to those hoses one of these days...they're just sitting there annoying me, like the money I could be saving with Geico.
« Last Edit: June 06, 2009, 06:21:30 PM by DesktopDave »
