As Dave suggested, use your VIN on either "realoem" or "bmwfans.info" and part numbers for both systems (disk or drum) will be listed. I think I would print the sections out, highlight the parts I need and start scrounging the junkyards:p
I've done brake work on a '95 E36 "316i" Coupe, '95 E36 "316ti" Compact and a '93 E36 "318i" Sedan and all had drum brakes.
My suggestion:
- If your drum brakes are at the point of needing replacement, switch to the disk brake system.
- If your shoes/drums are in good condition wait until wear limits are reached and then do the swap. In the meantime, adjust everything to specs and make sure the front brakes and both hydraulic systems are in tip top shape.
- Proceed with the M42 swap regardless:D
I just have to go with the m42 swap , because I want to F.I. it :rolleyes: , I always wanted a turbo car , ever since I was a kid
Wow - I'm surprised to hear that Romania is so overbearing. There'd be riots in the streets if the government attempted to regulate hot rodding.
Go for the swap, definitely!
yeah ...it's sad ...
so many laws, so many restrictions ...
it's sad ...
U guys in the states don't even know how envied u are , u guys have the biggest engines , and the cheapest gas ... so u can have more fun for less money than us , we pay in Romania 1,50 $ for 1 litre , that's just a third of a gallon ...
so we pay around 5 $ / gallon ...
truly sad
You're right, Dave, and I think what Alex relates is pretty much the norm for a lot of European countries. Those of us in the U.S. are extremely fortunate to have the liberties to modify our vehicles the way we do.
exactly ...
to change the rear brake system from drum to disc, u need to replace the pair of trailing arms attached with the disc brake system.. and also change the handbrake cables.. That's all... I believe you can get those from the scrapyard...
I've change mine before from drum to disc...
Could U elaborate a bit ? what exactly is to be done ? disconnect the outer wheel drum , the the drive shaft , then the shock , then the trailing arm ?
