Author Topic: Running coolant for a turbo  (Read 2676 times)
Awgy
« on: May 31, 2009, 04:43:03 PM »
I would like some input on how to run the coolant lines for my top mount turbo project.
I am thinking of using this drain bolt as my feed.
I don't have any ideas as to put my return. Or even if the feed spot is a good idea.
Any input on this situation?
Deftones
« Reply #1 on: May 31, 2009, 05:32:10 PM »
use the hose from the heater radiator but you won't use it anymore or use the pipings from the throttle heater
http://blogs.yahoo.co.jp/luca318is
1992 318is e36
1990 318is e30
bar73k
« Reply #2 on: June 01, 2009, 07:43:55 AM »
Delete your throttle body heater and use the water from there
