Author Topic: 318is and LSD swap?  (Read 3550 times)
Blip Bavarian
318is and LSD swap?
« on: May 22, 2009, 03:29:29 PM »
is the swap from a small case diff to a med case diff a direct swap.  Do you use all of the same hardware from the small case??
will a diff from a e34 be a direct bolt on replacement??  Sorry for all the noob questions...
« Last Edit: May 22, 2009, 03:37:42 PM by Blip Bavarian »
1991 E30 M42
318is and LSD swap?
« Reply #1 on: May 22, 2009, 04:29:21 PM »
the med case is a direct swap and uses the same hardware, i think the e34 diff will fit if you use an e30 cover
Blip Bavarian
318is and LSD swap?
« Reply #2 on: May 22, 2009, 05:53:19 PM »
the  cover from my small case?    anyone else know about a e34 diff in the e30?
Quote from: 1991 E30 M42;72271
1991 E30 M42
318is and LSD swap?
« Reply #3 on: May 22, 2009, 11:04:03 PM »
the cover from a med case, i am not 100% sure that the e34 diff swap will work, so do the research
fabe
318is and LSD swap?
« Reply #4 on: June 02, 2009, 09:06:45 AM »
from what i know there are 2 versions of the E34 rear diff casing. Do check properly..
And yes, if you get the right E34 rear diff, just need to change the rear cover from an E30 med casing... and also the output flanges needed to be changed too... I've done it before.....
fabe
318is and LSD swap?
« Reply #5 on: June 02, 2009, 09:08:44 AM »
deleted.. double postin...
xwill112x
318is and LSD swap?
« Reply #6 on: June 02, 2009, 09:15:13 AM »
just buy a 4.10LSD from a 325iA and swap it in, then your good to go. A m42 probably wont tear out one of those.
Ich liebe meinen E30
