Author Topic: Get Power Out Of Stock M42  (Read 6338 times)
laernu
« Reply #15 on: May 23, 2009, 05:30:47 AM »
lol no thanks Danny707 i saw that up for sale awhile back.. Also how would i go about getting a lower LSD
SoupieMelody
« Reply #16 on: May 23, 2009, 07:29:28 AM »
Quote from: tjts1;72148
Ditch the power steering, electric cooling fan, 3.73 LSD, 22# EV6 injectors, ebay chip, high beam sealed intake, cat back if you have cash left over.
http://www.m42club.com/forums/showpost.php?p=64009&postcount=7
good luck
Justin
with all this what is your 1/4 mile?
  • -Receive: 5
« Reply #17 on: May 23, 2009, 11:56:58 AM »
Read #2
« Reply #18 on: May 23, 2009, 02:12:33 PM »
Quote from: tjts1;72288
No because it forces you to shift more often which increases your acceleration times. With the stock 4.10 differential you have to shift to 3rd at 55mph and 4th before the end of the 1/4. A 3.73 on the other hand gets you to 62mph and you can complete the quarter in 3rd gear. Each shift ads between 0.5-1.0 second to your times.
http://www.m42club.com/forums/showpost.php?p=26477&postcount=28
Yep - have to agree.  Although the car is slower (except statistically), my 3.73 makes first gear worthwhile.  Anything shorter essentially makes the car into a four-speed (unless it's a really steep hill).
Bmw02er
« Reply #19 on: May 23, 2009, 02:20:50 PM »
tjts1 do you have a link to those injectors (22# EV6) you are talking about? Google gives me very different results. Webshop maybe?
TIA!
Blip Bavarian
« Reply #20 on: May 23, 2009, 07:33:07 PM »
that makes since for straight line or 1/4 mi times, but in theory it seems for the track or auto x you would want the car geared lower to keep you in the power band more of the time.  Im noob, so that is just my guess.
I went to the jy today to look for some parts and found a 3.73 med case lsd w/ 130k on it.  I can get it for $100 so ill prob go back on Monday and pick it up.  does that sound like a good deal?  Are most of the M42 guys running 3.73?
Also, what is the % lockup for these oem lsd diffs??:)
  • -Receive: 5
« Reply #21 on: May 23, 2009, 09:48:50 PM »
Quote from: Bmw02er;72315
TIA!
http://m42club.com/forums/showpost.php?p=71617&postcount=137
Quote from: Blip Bavarian;72325
I like my 3.64 small case specifically for autoX because I never have to use 3rd gear and I can keep it in 1st gear through a lot of slower sections. With a chipped 7200rpm red line its even better.
The only reason I'm using a 3.64 small case diff is because I couldn't find a 3.73lsd in the local yard. Somebody in the area has take to buying up all the LSDs as soon as they hit the yard only to resell them on ebay. Fucking bastard. So yes, $100 for a 3.73 lsd is a great deal. I would be all over that like like stink on shit. Make sure to reseal the diff cover and replace the big bushing at the top with a solid M3 piece before you install it into the car. Its also easier to fill it up with oil before you have in the car.
Good luck
Justin
Blip Bavarian
« Reply #22 on: May 24, 2009, 03:57:42 PM »
Awesome, thanks for the advice Justin.  I will pick that diff up tomorrow.
Do you know the part #'s or have a link to a diy thread that shows what additional bushings etc i should replace?  I bought this car for the learning experience, so most of the wrenching is new to me, but im determined to figure it out.  Thanks again. -Matt
Quote from: tjts1;72332
Good luck
Justin
« Reply #23 on: May 24, 2009, 10:16:48 PM »
the LSD lockup is 25%, assuming everything is in good shape. A lot of them are a bit worn out by now.
The only main suspension bushings on the car are control arm bushings, rear subframe bushings, diff bushing, and trailing arm bushings. i have all AKG poly bushings on my car, from AKGmotorsport.com. Great parts, but its a little harsh. you can get pretty much the same thing with M3 offset control arm bushings, 70A poly subframe bushings, stock trailing arm bushings, and M3 diff mount.
Also be sure to check your rear shock mounts. those things always blow out if they are stock.
