Author Topic: speedo quit!  (Read 3730 times)
3seriesNut
speedo quit!
« on: May 06, 2009, 03:41:07 PM »
my speedo started going nuts a few days ago. when i would down shift it would bounce of 0 then back to speed. then today its not working at all.
is there a speed sensor in the rear or is the guage shot?  if it is shot would the speedo from a 325 work? it looks like its a motherfucker getting to the gauges tho :(
speedo quit!
« Reply #1 on: May 06, 2009, 04:18:13 PM »
Speed sensor is mounted through the rear differential cover - the wires have a habit of breaking back there. I'd look at that first.
3seriesNut
speedo quit!
« Reply #2 on: May 06, 2009, 04:44:02 PM »
thanks john. after looking at the scematics i found the speed sensor. its raining again today so im not messing with it. my GPS has a fairy accurate speedo in it.
1991 E30 M42
speedo quit!
« Reply #3 on: May 07, 2009, 02:52:55 AM »
did you try smacking your dash just above the cluster, it works every time for my coolant temp sensor
3seriesNut
speedo quit!
« Reply #4 on: May 07, 2009, 05:07:47 AM »
does nothing. im thinking its the speed sensor wiring.
