Author Topic: Reupholster sport seat?  (Read 21964 times)
Old2002Driver
« on: May 04, 2009, 08:20:06 PM »
What success have you had with reupholstering a driver's side sport seat.  My tan interior is very decent except for the usual driver's side wear.  Would like to investigate a redo.
Any idea as to likely cost?  Suggestions as to source around Atlanta.
Thanks for any comments.
Old 2002 Driver
Atlanta, GA
91 318is
04 Mini Cooper S
99 Mazda Miata
« Reply #1 on: May 04, 2009, 09:05:55 PM »
Upholstery shops around me tend to charge around $350ish for an entire seat done in leather, and a very good job at that. dunno about ATL though.
twright
« Reply #2 on: May 06, 2009, 06:49:46 AM »
You can also get individual panels replaced for considerably less.  I had one panel replaced on the back of a vinyl seat for $65.
dbgrubbs
« Reply #3 on: May 06, 2009, 02:15:28 PM »
Ummm, call Kevin Chin. He's just south of Atlanta. He does BMW seats as well as anyone. Here's his outdated website but just call him.
http://www.creativeoptions.info/
KenC
« Reply #4 on: May 06, 2009, 03:07:19 PM »
I just transferred everything from a passenger seat.  Looks fantastic.
Old2002Driver
« Reply #5 on: May 10, 2009, 08:26:34 PM »
I just bought a passenger seat to use for parts temporarily.  How do the pieces detach?
Old 2002 Driver
Atlanta, GA
91 318is
04 Mini Cooper S
99 Mazda Miata
« Reply #6 on: May 12, 2009, 04:23:21 PM »
I ordered a micro-suede kit from Kevin Chinn.  I think there's about 1 week left before he can get to mine.  He has a very good reputation on the BMW forums.
monty23psk
  • -Receive: 17
« Reply #7 on: May 12, 2009, 05:50:54 PM »
He is the best, he did my mtech cloth and micro combo. Just waiting on the door panels so I can install the rear and then work on front seats. Easy to install once you get use to the hog ring tool.
« Reply #8 on: May 20, 2009, 03:07:35 PM »
Door panels eh?  Do you have any pics or details about them?  I would like to swap the all-vinyl ones to some vinyl/micro ones to match (or maybe all micro).
monty23psk
  • -Receive: 17
« Reply #9 on: May 20, 2009, 03:17:26 PM »
Still waiting for them. The vinyl is OEM and coming from Germany. I will post pics under my profile here on m42 when I receive them.
Old2002Driver
« Reply #10 on: May 27, 2009, 07:09:25 PM »
I just picked up a pair of tan vinyl seats from a list member. Passenger is perfect.  Driver has minor split on left bolster.  I have a good bolster from my current passenger seat.  Can somebody give me some specifics on how to swap covers?  It appears that there are pointed metal tabs  that pierce the fabric and then are folded over.  Is this the only attachment?
Thanks for any help.
Old 2002 Driver
Atlanta, GA
91 318is
04 Mini Cooper S
99 Mazda Miata
TomO2UT
« Reply #11 on: June 22, 2009, 06:08:44 PM »
I put a set of BMW factory cloth replacement covers on my driver's seat recently. I looked at Purcell's website about rebuilding seats to see how to take them apart. It is a bit tricky the first time but Purcell's instructions are sufficient. I think you will need to remove the seat back from the bottom--at least I did.  I pretty much took the seat completely apart.  The cushions and bolsters are attached with hog rings and tabs on the steel frames. I took photos and made sketches before prying the hog rings off with needle nosed pliers. I'm not sure the effort was worth it, but the hog rings I found at upholstery shops were either much heavier (too big and very hard to use) or lighter (too small). (Rings are available from the dealer, too, but by then I didn't want to wait). I also cut some off with nippers (much faster). The fabric/vinyl is held to the foam cushions with long, thin staples. My staple gun didn't work at all, so I pulled and re-inserted all the staples by hand--it worked fine. The bolster covers slide right over the foam and are held in place by long wires and hog rings--no staples. I got the hog ring pliers at an auto parts store. The seats turned out better than I expected. I replaced my worn foam with foam from a pair of junkyard seats. Good luck.
TomO2UT
« Reply #12 on: June 22, 2009, 06:14:53 PM »
My first attempt to post a photo--completed seat, with factory anthracite cloth--about $450 total for back and bottom.
KenC
« Reply #13 on: June 22, 2009, 06:27:32 PM »
I just used a bunch of zip ties instead of hog rings.
E30_80Y
« Reply #14 on: August 12, 2009, 09:30:08 AM »
Quote from: TomO2UT;74083
What is that website you speak of? I cant seem to find it on google. I cant seem to figure out how to remove the bottom piece, where the shaft holds the fabric. Can anyone please help?
