Help no fuel no spark
Author Topic: Help no fuel no spark  (Read 4072 times)
ozzyis
« on: July 13, 2006, 07:47:35 PM »
I have a 1990 318is went to start it one day and no go. I have had the ecu tested its fine, i have replaced the main, fuel pump and o2 relays. Still no go. I can't hear the fuel pump when i turn the ignition on and there is no spark although there is power at the coil. If anyone can help me it would be greatly appreciated.
zerofreez
« Reply #1 on: July 13, 2006, 09:02:15 PM »
Does the engine crank?
Do the spark plugs smell like gas after cranking?
Do you have compression?
ozzyis
« Reply #2 on: July 13, 2006, 09:06:18 PM »
Hey how ya goin
Yes the engine does crank, it has compression i havn't had a look at the plugs but pulled the fuel line off and cranked the car and not a drop.
« Last Edit: July 13, 2006, 10:11:54 PM by ozzyis »
« Reply #3 on: July 20, 2006, 05:18:57 PM »
Well, probably a deap pump.  If you are lucky it is just a clogged filter.  Remove the back seat and listen for the pump whine.
ozzyis
« Reply #4 on: July 24, 2006, 10:23:52 PM »
Yeah i have pulled the seat out already but the pump is not making any noise at all, this is what i first thought it was, but to lose spark and fuel at exactly the same time seems a bit odd.
« Reply #5 on: July 24, 2006, 10:44:08 PM »
hows your crank sensor?
ozzyis
« Reply #6 on: July 26, 2006, 12:07:06 AM »
I'll check it out and get back
ScentOfGasoline
« Reply #7 on: August 01, 2006, 09:51:08 AM »
check pump by applying 12 V directly at the pump.
check for voltage at the pump when cranking the engine
remove fuel pump relay and check voltage with ignition in ON position (no cranking)
