E36 M40 318i Turbo .
Author Topic: E36 M40 318i Turbo .  (Read 37430 times)
naika
E36 M40 Turbo oil-drain placement ??
« Reply #15 on: September 25, 2009, 03:21:18 AM »
Thanks for the answers, I was talking about the Air flow meter (not the AFR :) ) the AFM that is usually on the driver side and that installed between your cone filter and the turbo.
I wonder if there is any gain in doing that?
I'm impressed that you manage to boost over 1 bar on stock internals, that pretty crazy ;)
E30 forever!
fazerfreak
« Reply #16 on: September 25, 2009, 12:47:03 PM »
ops. sorry.. the reason for placing it infront of turbo is that i´ve heard that the AFM can´nt handle the turbo pressure and supposely easier to adjust right.
Tommy
My E36 M40 Prodject in norwegian, sorry, but pictures :D
My E36 M40 in M42club
naika
« Reply #17 on: September 25, 2009, 03:24:53 PM »
that's a good idea, and it works without any problems? because if it does, I'll install mine that way. I guess you didn't have to modify anything, besides putting longer wires for the AFM plug, right?
E30 forever!
fazerfreak
« Reply #18 on: September 25, 2009, 03:56:04 PM »
works perfect, longer wires for the afm and tightning the "spring?" inside the afm, (about 25 clicks) used the afr ;) to see when i hitted a nice blend.
Tommy
Danny707
« Reply #19 on: September 26, 2009, 03:29:25 AM »
The AFM can handle boost pressure, it just doesn't read it as boost, just as hotter air.
So Fazer has the AFM in the spot it really should be in.
fazerfreak
« Reply #20 on: September 27, 2009, 04:41:45 AM »
the one i have have a "door" inside that messures pressure as well i think?
Tommy
naika
« Reply #21 on: September 27, 2009, 12:33:43 PM »
so is it basically better to have it in the OEM spot or that wa fazer has it?
E30 forever!
Danny707
« Reply #22 on: September 27, 2009, 01:35:51 PM »
For turbo, the way fazer has it.
The AFM can't read anything above atmospheric pressure.
naika
« Reply #23 on: September 28, 2009, 10:13:26 AM »
Alright, thanks ;)
E30 forever!
