Smokey M42
Author Topic: Smokey M42  (Read 4815 times)
Pac_Man
    • http://www.PSUK.BTtradespace.com
Smokey M42
« on: April 29, 2009, 10:18:53 PM »
Just wondering if anyone can give me a more educated decision on what’s causing my M42 to smoke.
The car starts up fine, and has a nice idle, it also feels to have plenty of power left and does not run lumpy but when I give it some beans its leaves a nice smoke cloud behind me.
When I’m taking my time and keeping it under 4k on the rev gauge it does not smoke at all.
The only other sign of oil is sometimes when I start from cold it spits some oil out the exhaust leavening residue on the floor.
My guess is one of three things either valve stem oil seals, worn piston rings or worst case a cracked head.
If its valve stems or pistons rings I’m temped to get it sorted however if it’s a cracked head I’ll just source another M42 to drop in.
Any info or advice is much appreciated
Alpine White E30 318is
1991 E30 M42
Smokey M42
« Reply #1 on: April 30, 2009, 02:25:07 AM »
what color is the smoke, white black or blue
Pac_Man
Smokey M42
« Reply #2 on: April 30, 2009, 10:07:22 AM »
Its bluey gray and smells of burning oil
cleaner32
Smokey M42
« Reply #3 on: April 30, 2009, 01:50:09 PM »
cleaner32
Smokey M42
« Reply #4 on: April 30, 2009, 01:50:47 PM »
Oh, across the pond
Birdman16
Smokey M42
« Reply #5 on: April 30, 2009, 03:54:46 PM »
If your oil is milky then you have a cracked head.  It should blow white smoke after it warms up and black smoke when uou start if if it is the head.
GOOD LUCK!!!
From The Gumball Rally
Family Rides:
Dad: 03 325i (E46)
Pac_Man
Smokey M42
« Reply #6 on: April 30, 2009, 04:42:20 PM »
Its only ever smokes when i give it some and even then its not all the time, no black smoke what so ever
1991318is
Smokey M42
« Reply #7 on: April 30, 2009, 11:37:09 PM »
Sounds like its definitely oil, but sadly I think you'll need to pull it apart to tell with any certainty where the oil is coming from and whats broken.
John W
Smokey M42
« Reply #8 on: May 02, 2009, 08:32:53 PM »
What brand/viscosity oil are you running? I had an old 2002tii that burned oil quite a bit on Castrol GTX (what the PO used) and switching to Valvoline 20w-50 improved the smoke thing considerably as well as reduced oil consumption.
1991 BMW 318is SOLD :(
1976 BMW 2002 m20
2005 Ford Focus ZX-3
visionracingdevelopments
Smokey M42
« Reply #9 on: May 03, 2009, 04:06:54 AM »
Quote from: Birdman16;71157
GOOD LUCK!!!
Could it not be a combination of leaking seals and a head gasket ion the way out?
http://www.visionracingdevelopments.co.uk
For sale:
COP converion kits
M42 Silicone coolant hose kits
Braided brake line kits
Performance clutches
Performance brakes
PM me
