Author Topic: 5th Gear Troubles  (Read 2256 times)
SonomaGTLN2
5th Gear Troubles
« on: April 25, 2009, 10:50:41 AM »
I am having trouble shifting into 5th gear...all the other gears shift smoothly but 5th goes into gear and when I disengage the clutch it wants to jump out...once cruising it stays in gear fine on and off the throttle. I just changed the fluid last year so I don't think it's that...  Any ideas?
M42 Swap a success!...so far:rolleyes:
nicknikolovski
5th Gear Troubles
« Reply #1 on: April 26, 2009, 01:44:06 AM »
What about the selector bushings? Check them out.
charlesmarseille
5th Gear Troubles
« Reply #2 on: April 28, 2009, 02:48:37 PM »
same problem with the 4th gear, wants to jump out and i got to slam it in. wierd noises come from the tranny, i dont really like it. heard by my mecanic friend that its the back synchros, could it be the culprit?
Isamemon
5th Gear Troubles
« Reply #3 on: April 28, 2009, 03:00:37 PM »
how many miles ?
I know not the same rig, but a friend wore out his shifting forks, casue when he drove he rested his hand on the shifter a lot, puttiong pressure on the shifter fork, slowly wearing it, at least thats what the mechanic told him, cause the rest of the tranny was fine
SonomaGTLN2
5th Gear Troubles
« Reply #4 on: April 28, 2009, 05:20:04 PM »
Quote from: Isamemon;71016
how many miles ?
Interesting, I do the same, though I've only had the trans for 3000 miles.  Overall its about 130k on the trans/motor.
Thanks for the responses, I'll probably just pick up a spare and dismantle this one to see what it looks like inside.
AJ
