Author Topic: headlight issues  (Read 3286 times)
3seriesNut
headlight issues
« on: April 14, 2009, 08:49:54 PM »
i just noticed that when i turn my high beams on the drives side low beam goes out. what causes that and how can i fix it? also is there a way to wire the fogs so they dont go out when the highs are on?
1991 E30 M42
headlight issues
« Reply #1 on: April 14, 2009, 11:23:25 PM »
you need a new headlight, the low beam on the stock sealed beam lights is a dual filament, one is for low only, and the other runs off of the high beam circuit
3seriesNut
headlight issues
« Reply #2 on: April 15, 2009, 05:09:42 AM »
might as well change all 4 to hella's that i can actualy change the damn bulbs in then.
3seriesNut
headlight issues
« Reply #3 on: April 15, 2009, 09:31:33 AM »
both low's went out now. what do i need and where do i get it at to convert to hella halogen type setup?
FL318is
headlight issues
« Reply #4 on: April 15, 2009, 10:17:01 AM »
Mine did the same thing but I cannot remember what I did to fix it.  I can now run the fogs with the high beams on.
I seem to recall a diy link to somewhere that required a wire jump in the fuse box. Sorry for the lack of information.  I will try and research it for you.
3seriesNut
headlight issues
« Reply #5 on: April 15, 2009, 10:32:47 AM »
ive searched and came up with nothing of use. might be better off to replace all 4 lights.
3seriesNut
headlight issues
« Reply #6 on: April 16, 2009, 04:27:17 PM »
Quote from: Gossioii6;70221
This is great! Now I want to see your ways for us readers to become more involved! Expect an email later today.
what a douchebag
